CompCertSSA
 A companion web page
    CompCertSSA is built on top of the C CompCert verified compiler, by
      adding a SSA-based middle-end (conversion to SSA, SSA-based
      optimizations, destruction of SSA). This web page reports only on the
      parts of the development specific to this SSA middle-end. The complete
      development is available below.
    Papers
      -  A formally verified SSA-based middle-end. G. Barthe,
        D. Demange, and D. Pichardie. ESOP 2012.
      -  Formal Verification of an SSA-based Middle-end for
        CompCert. G. Barthe, D. Demange, and D. Pichardie. ACM TOPLAS
        2014.
      - Verifying Fast and Sparse SSA-based Optimizations in
        Coq. D. Demange, D. Pichardie and L. Stefanesco. CC 2015.
        more
      - Validating Dominator Trees for a Fast, Verified Dominance Test.
        S. Blazy, D. Demange and D. Pichardie. ITP 2015.
        more
      - Mechanizing Conventional SSA for a Verified Destruction with
        Coalescing. D. Demange and Y. Fernandez de Retana. CC 2016.
        more
      - A Fast Verified Liveness Analysis in SSA Form. JC. Léchenet,
        S. Blazy, D. Pichardie. IJCAR 2020.
        more
    Coq Formalization
 Project, and releases
         Access the Gitlab project here, or
          get the latest release.
       CompCertSSA quick start
            -  Compiling CompCertSSA follows the same process as for
            CompCert (see
            manual).
            -  Usage of CompCertSSA: same as CompCert, but with
            the
-ssa option, e.g.
	       ./ccomp -ssa on [target]
            -  Help on CompCertSSA: same as CompCert, with
                ./ccomp --help
     Browsable version of files specific to the SSA middle-end.
         Below is a commented listing of the underlying Coq
	  specifications and proofs.  Proof scripts folded by default,
	  to unfold, click on "Proof".
	  -  The whole compilation chain, with middle-end plugged
	    in:
            Compiler
            Complements
	  -  RTL transformations, previous to SSA generation
	  -  SSA form: definition and validation
	  -  SSA properties and libraries:
	  -  Optimizations :
 -  CSSA form (Conventional SSA) :
          -  RTLpar, RTL with parallel-copy blocks:
          -  Deparallelization of copy-blocks, from RTLpar to RTL:
            RTLdpar
            RTLdparspec
            RTLdparproof
